GPIB-ENET driver 1.10 no longer works under Windows 2000 service pack 2
I have used my GPIB-ENET adapters with Windows 2000. However, since I installed service pack 2, the GPIB driver 1.10 no longer works. It seems to install correctly and puts the GPIB icon in the Control Panel. After a reboot, however, the icon is gone from the control panel ! It is even gone from the install/remove programs box. I have tried this on two PC's with the same result. This is really bad as my GPIB-ENET boxes are now useless. Can you help with this?
(3,658 Views)
The latest driver available for GPIB-ENET under Win 2000 is 1.2 and it is available on our web site ( http://www.ni.com/support/gpib/versions.htm ). Try downloading that driver and using it for your ENET Box.
(3,658 Views)
Thanks for the advice, but the 1.20 drivers cannot be downloaded. They must be purchased for $80 US. I have already paid many thousands of dollars for three GPIB-ENET adapters plus LabVIEW. This is really shabby. I know of no other company that charges for driver updates once you have bought the hardware. I should have bought the Tektronix adapters instead.
(3,658 Views)
When you install the driver, can you assign an IP address to the GPIB interface and run IBIC to test it? Are you still able to use IBIC?
(3,658 Views)
