GPIB -ENET100 doesn't work with HP11713A Attenuator/Switch driver
I have problem using this combination of devices. The Att/Sw driver is  not visible in Measurement and Automation explorer. However it is compleatly visible and operates properly when I use PCMCI card. Apparently it is a problem of ENET100. All sugestions are very welcome!
(3,104 Views)
I found the problem for not showing in the Explorer tree - GPIB connector of the device was partially inserted 🙂 , however it is not possible to addres (initialize) this device with enet100. No problem with PCMCI card...
(3,099 Views)
