GPIB PCI configuration
HI,
We have an old ISA GPIB board working with a production machine. The card is setup wirh IRQ and adresses.
We tried to replace this board by a PCI GPIB but we are unable to set the same parameters.
Is there a way to set these parameters in a PCI GPIB?
See photos of your ISA Board.
We have a PCI GPIB Card (778930-01)20150723_124039_resized.jpg20150723_124047_resized.jpg20150723_124056_resized.jpg
Bests Regards,
AN
(5,175 Views)
Hellp gtitechnologies.
I would like to know how are you configuring this variables. Please provide me more information and I´ll try to help you with recommendations.
Regards
(5,062 Views)
I don't think that configuring IRQ and address is your problem. PCI is using autoconfiguration. So there is no need to configure that.
Probably you have another problem. May be the installed/used  drivers are too old to support the PCI card,  May be  the PCI card is recognized as second GPIB controller (gpib1). But it needs to be the first ( gpib0) .
Could you tell us more about the production machine ?  Which OS does it run, which version of GPIB drivers is installed ?   How does the software running on the production machine access the GPIB-driver ?  Is  it linked  statically or dynamically against the GPIB driver ?
(5,027 Views)
