Software versions are as follows:
NI 488.2 version 1.10
MAX 2.1.3.15
NI Spy 1.4
USB-A gets detected properly and there was nothing specific to troubleshoot.
When the Tektronix Wavewriter software is used to download an arbitrary waveform to the Tektronix AFG 320, the software posts an error dialog indicating "Error sending waveform to AFG300". However, NI-Spy does not capture any failures whatsoever.
I must mention here that if we use the MAX software to download specific commands to the AFG320, most of those get executed successfully. It is only the Wavewriter software that seems to have a problem with downloading waveforms.
Tektronix believes that this may have something to do with the fact that Wavewriter software is a 16-bit applicati
on whereas the GPIB-USB-A may not be supporting 16-bit applications. If this is true, when can we expect a driver for the GPIB-USB-A device that supports 16-bit applications too? If a specific time frame is known for its release then I will appreciate info on that. Thanks.
Dr. Prasad Ramanathan
