GPIB-USB-HS(780570-01)
Hi team,
I would like to ask if this product can only use the usb interface to connect the pc and the GPIB interface to connect the device.
Our host is a GPIB interface, and the slave or test device is a USB interface. Can we use this device to control the host to the slave?
Looking forward to your help.
(1,272 Views)
This device is made to have the PC as the USB host. You will need the NI driver for the device to work properly.
I don't recommend this cable for your application, unless your target is a Windows device that supports NI-488.2 (check the readme of the software to know the supported operating systems and devices).
Cheers,
(1,262 Views)
