GPIB-USB-HS Question?
I have recently purchased a GPIB-USB-HS cable and have a question.  I know this device is for USB 2.0 and I have hooked it up to a computer with USB 2.0 and it has worked fine.  When I try to hook it up to a computer with USB 1.0, the computer can not see the cable.  Does this make sense?  Any help would be appreciated.
Azazal
Message Edited by Azazel on 07-19-2005 11:26 AM
Azazel
Pentium 4, 3.6GHz, 2 GB Ram, Labview 8.5, Windows XP, PXI-5122, PCI-6259, PCI-6115
(3,679 Views)
It makes sense to me that a device designed specifically for the higher bandwidth of USB 2.0 would not work on a USB 1.0 port. You might want to check the published requirements specification if the minimum is USB 2.0. If it is, a pci card with USB 2.0 ports is real cheap.
(3,665 Views)
A USB 2.0 device should work with a USB1.x host although it will only function at USB 1.x speed.
Does the OS not detect anything when you plug in the GPIB-USB-HS? Do other USB devices work in that USB port? Have you tried different USB ports on the same system?
(3,658 Views)
