GPIB-USB-HS connector
Few days back, we got a quotation for the GPIB-USB-HS connector (part no. 778927-01). In the quotation, we saw that it comes with software that is compatible with windows 7 and windows XP. Our system has windows 10 in it. Can you please confirm whether the item will be compatible with windows 10? If not, please let us know which one will be compatible with windows 10.
(1,253 Views)
That part is marked as "Mature", which means it will soon be discontinued.  You should probably get a quote for GPIB-USB-HS+ (part number 783368-01).  It is also listed as $500 cheaper.
As far as software is concerned, it looks like you just need to use a version of NI-488.2 21.0 or newer to be compatible with Windows 10 (NI Hardware and Software Operating System Compatibility).
(1,229 Views)
Thank you for your reply.
(1,175 Views)
