GPIB-USB-HS is not recognized properly in NI MAX and cannot be found in NI VISA resource
Thank you.
I had a look and "ni488enumsvc" is running. That must not be the problem then.
Message 11 of 13
(3,340 Views)
The problem was that the USB-GPIB-HS modules I tried was physically broken. I tried another and everything worked.
Message 12 of 13
(3,332 Views)
I had the same issue and this answer helped. Thank you!
Message 13 of 13
(975 Views)
