GPIB-USB-HS "Instrument not found"
Hai ,
            I have connected my laptop with signal generator using GPIB USB HS interface card .
I have installed NI 488.2 version 2.7.3. in myaptop.
After i connected to my laptop In device manager , i can able to see "National Instruments " under that "GPIB USB HS"
But in the Measurements & Explorer tab , after i gave scan for instruments , it is showing "instrument not found"
Can any one please help me ? It is very urgent . How to find the connected instument gpib address?
(3,858 Views)
Which instrument are you connecting and is the connector good connected?
I've seen that the usb-gpib-hs is a bit bigger than a gpib connector itself and on an old Rhode and Schwarz generator almost fitted, but not good enough.
try a cable extra.
greetings from the Netherlands
(3,851 Views)
i have connected with IZT DSG2000 signal generator . Also "Ready " Led is illuminated in GPIB card.
(3,849 Views)
Looks there is plenty of space on the connectorside
(3,834 Views)
