‎06-29-2018 11:07 AM
I have searched for an answer for this and cannot find anything. Does the GPIB-USB-HS+ adapter have memory that would require a sanitization procedure. I need this information for a hardware baseline on a classified test stand.
Solved! Go to Solution.
‎07-02-2018 07:59 AM - edited ‎07-02-2018 08:00 AM
Might be easier if you were to list the manufacturer and their device information. Also, we have seen a number of counterfeit NI ones listed in this community that do not work properly and have the wrong P/N's or S/N's.
‎07-02-2018 09:10 AM
NI typically provides information about memories in a "Letter of Volatility"
The one for the HS+ is here http://www.ni.com/pdf/manuals/374618a.pdf
‎07-02-2018 09:50 AM
Thank you James-G that is what I was looking for
‎07-02-2018 10:30 AM
Please mark James-G reply as the solution to this forum question.
Warm regards,
Gustave
