GPIB-USB on linux kernel 2.6.28 troubleshooting
We are trying to get NI GPIB-USB working on a linux kernel 2.6.28.9 that we have built ourselves. This kernel is not in the list of supported kernels in NI's documentation.
I have got ni4882-2.9.0f0.tar.gz to install on our linux machine, but am struggling to get USB GPIB dongle to be recognized (bound to the appropriate driver).
What works so far:
- ni 4882 version 2.9 installs okay (as far as I can tell)
- lsmod | grep ni => shows nikal, nipalk, ni488lock, ni488k modules
- as soon as the USB GPIB dongle is plugged in, "/dev/nigpib -> usbdev2.3_ep84" gets created indicating that the usb device was picked up
What does not work:
- gpibtsw starts up and declares error (red cross sign) on "NI 488.2 software presence verified" indicating that we had a software installation problem
- gpibexplorer startsup and has an empty list of GPIB interfaces indicating that the USB GPIB interface was not recognized
- under /sys we can see the usb device but it is not bound to any driver
What does not look right:
- Under /sys, I only see a PCI GPIB driver under /sys/bus/pci/drivers/ni488. But I do not see any USB GPIB driver that I would have guessed to appear under /sys/bus/usb/drivers.
Things we have tried so far:
- ni4882 examples: devquery reports error ENEB (No GPIB Board) and findstr reports error EDVR (Driver Error)
- we built our own examples to try calling SendIFC, ibdev, ibconfig (to configure). But all report errors indicating they cannot talk to the board or driver
- manually executed 'etc/init.d/gpibenumsvc start' to see that makes any difference. None so far.
- tried NI gpib version 2.5.1 on the target but it fails to build nikal.c because the kernel is a lot newer than what version 2.5.1 supports in code. There will be a lot of patches to fix that (even if we attempt to)
- tried to install NI gpib 2.9 on a Suse 11.2 installation to check if I can find any USB GPIB driver that gets installed under /sys/bus/usb/drivers but that does not give anything different that what we see on the 2.6.28.9 kernel that we built ourselves.
Any help would be appreciated.
thanks in advance,
Anil
(4,676 Views)
Anil,
Since the kernal is not supported, there is little we can do for you. However, as an idea I would recommend using this trouble shooting command
/usr/local/natinst/ni4882/bin/gpibts
suggested by the manual on the NI 488.2
http://www.ni.com/pdf/manuals/371334c.pdf
Let me know if you've already tried this.
Ben D.
(4,656 Views)
Hi Ben:
thanks for the reply.
I have tried gpibtsw and it declares error (red cross sign) on "NI 488.2 software presence verified" indicating that we have a software installation problem. Also have tried gpibexplorer that has an empty list of interfaces indicating it could not find our gpib usb interface.
One question: I cannot see the GPIB-USB driver in the installation. The only driver I can see is the PCI-GPIB /sys/bus/pci/drivers/ni488.
Where should I look for the GPIB USB driver after installation?
thanks,
Anil
(4,652 Views)
Because you have a custom kernal there isn't much we can do on our end. I can say that if it's a PAE kernal, we guarantee it won't work. I understand that your needs may require a custom kernal, but we can only support kernals we are familiar with. I'm sorry and good luck.
Ben D.
(4,629 Views)
Unfortunately, the NI-488.2 driver no longer works with USB as of kernel version 2.6.25. Changes were made to the USB kernel stack in 2.6.25 which makes it incompatible with the NI-488.2 driver.
-Jason S.
(4,621 Views)
