GPIB; Visual Basic
Hi, I use GPIB to control our device (frequency syntheiszer). Under interative control mode,
I can set the frequency to my device (for example 10MHz). The commonds used are:
:ibdev 0 16 0 13 1 0
ud0: ibwrt "F010000000\n"
Then I use the Visual Basic programming language as:
Dim Dev As Integer
Call ibdev(0,16,0,13,1,0,Dev%)
Call ibwrt(Dev%,"F010000000\n")
The device can still set to 10MHz. However, if I change the frequence to 20MHz as
Call ibwrt(Dev%,"F020000000\n")
The device are still at 10MHz.
Who knows the answer, I really apprecite it.
(4,020 Views)
Hi Dreamhawk
You mention that the command
Call ibwrt(Dev%,"F010000000\n")    works but
Call ibwrt(Dev%,"F020000000\n")    does not.
You also mention
ud0: ibwrt "F010000000\n"    works
does
ud0: ibwrt "F020000000\n"    work?
If not you may try:
ud0: ibwrt "F011000000\n"
and
ud0: ibwrt "F015000000\n"
to move incrementally closer to 20 MHz..
John E.
Applications Engineering
(3,990 Views)
It seems like a string termination problem.
You are using Visual Basic language, not C/C++.  Therefore you can't use "\n" escape sequence to express control characters such as LF (0x0A).  Instead, you must write:
Call ibwrt(Dev%,"F010000000" & vbLF)
or
Call ibwrt(Dev%,"F010000000" & Chr(10))
(3,980 Views)
