GPIB analyzer error
I am a new user to Labview 7 Express. While running the GPIB analyzer for the instruments scanned I get an error titled MISSING CARD ERROR: Supported GPIB+ interface not found.......It also list some steps to troubleshoot but they does not work in my case (Installing the GPIB+ interface, Scan for hardare changes or enabling the interface. I am attaching a screenshot of the error in jpeg format. Also, when I view the properties of my GPIB-USB-B, I do not get the resources tab (only General and Driver tabs are seen). What do I need to do to remve the error. Thanks in advance.
(3,767 Views)
The first thing I wanted to verify with you is what GPIB board you have. You will only be able to use the GPIB Analyzer with a GPIB+ board. These boards can be found at the following link.
http://sine.ni.com/apps/we/nioc.vp?cid=12461〈=US
Also, if you do have one of these interfaces, then I need to request more information, such as the driver version and OS you are using. Also, are able to communicate with your instrument successfully in MAX?
Hope this helps!
Steven B.
Applications Engineering
(3,767 Views)
