GPIB and MAX
Not sure if this is the right place but I will start here and see where it leads.
This is somewhat along the lines of, MAX Dosen´t Detects My GPIB PCI,  http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/MAX-Dosen-t-Detects-My-GPIB-PCI/m-p/1086117
I have an Agilent PCI GPIB, 82350B, card used to control a Keithley 2000 DMM.
The tester is used intermittently during the year and has been running for the time I came to see it first, now it has stopped working.
VISA Assistant for Agilent will communicate with the DMM and return the correct value, in this case resistance.
Teststand calls a Visual C++ 6.00 program to setup and read the value. This is where it breaks down as the DMM is set once to resistance and tries to make a reading but fails to do this.
I have MAX 3.1.1 (this is a Windows 2000,SP4) and it cannot see the GPIB card.
Should MAX see the GPIB card? I think the answer is no from the above link.
From the above solution it was suggested to use GPIB-488 Ver 9, but I cannot find it on the NI site, where can I fine it?
Any other suggestions?
Thanks for the help
Simon
(3,463 Views)
The link is referring to a Keithley GPIB board and a driver from them. A driver from NI will do you no good for a GPIB board from Agilent. You can, however, follow the instructions about the tulip passport if you want to  make the board visible in MAX. I don't think it will make much difference unless you are using the IVI steps in TestStand.
(3,460 Views)
I did try the tulip passport in MAX 3.1.1 but it still did not see the GPIB card.
I am trying to explore another way to access the DMM, if possible, to try to help to see where the problem may lay.
Thanks for the help
Simon
(3,457 Views)
Should not matter if its seen in MAX or not. You said it was your C++ program that was talking to the instrument - not NI TestStand.
(3,454 Views)
