GPIB and VISA Problem
I am writing program to communicate with Keithley 4200.  I have downloaded the instrument driver.
When I used the Check 4200 ID.vi, the GPIB write had an error with error code was 7.
However, when I changed the GPIB write to VISA write, the error did not happen.
Why this happen?
Attached are the graph of block diagram, one was using GPIB write, another was using VISA write.
Message 1 of 21
(5,674 Views)
Error 7 is a "Nonexistent GPIB interface". What are you setting the VISA resource name to?
Message 2 of 21
(5,640 Views)
The VISA resource name is GPIB0::17::INSTR.
The error was shown when using GPIB write.  It is fine when VISA write was used.
Message 3 of 21
(5,610 Views)
What GPIB card are you using? Is it from NI?
Message 4 of 21
(5,608 Views)
I am using GPIB-USB-HS from NI.
Message 5 of 21
(5,595 Views)
And what was the GPIB string you used?
greetings from the Netherlands
Message 6 of 21
(5,575 Views)
The string is "ID" and the address is 17.
Message 7 of 21
(5,535 Views)
use simply 17 in the string, and it should work.
Why did you put ID in the string?
Message 8 of 21
(5,496 Views)
Sorry.  I misunderstood your questions.  I have already using 17 in the string.  ID is the data I want to write to the instrument.
Message 9 of 21
(5,486 Views)
The only thing I can guess now is that the bus already was occupied by another program or max or hyperterminal or maybe gpib itself,
Do you close the session?
Message 10 of 21
(5,472 Views)
