GPIB and the HP8563 series
I am looking for some advise. Under HPBasic, there is the ablility to use the "@Sa_bin" command. This command is assigned to the Analyser address. Its function is to turn off the "Number Builder" inside the analyser, so that the data is pure binary.
Any Ideas, examples on how to achieve this using the NatInst Dll?
(4,252 Views)
Are you using a National Instruments analyzer card? The NI GPIB analyzer program shows the data as binary, hex, and ascii.
Ray K
NI Applications Engineer
(4,252 Views)
Ray K,
Yes I am using the NI card. I did try to use the ibwrt command you previously mentioned, without success. Which GPIB analyzer program?
wkboat
(4,252 Views)
