GPIB card not found in MAX
I have installed a PCI-GPIb card and it iworking fine but when i go to MAX to configure all the cards i have installed the GPIb card is not present. In the control panel he card is working ok and all it set up properly. How to get the GPIB interface to appear in MAX
Message 1 of 9
(5,008 Views)
You may need to refresh MAX by pressing F5.
Message 2 of 9
(5,008 Views)
Have tried that and have also tried to re-install the GPIB driver but to no joy !
Message 3 of 9
(5,008 Views)
What OS and what version of the software are you using? Did the NI-488.2 Troubleshooting wizard detect any problems?
Message 4 of 9
(5,008 Views)
Windows 2000
MAX 2.2
PCI - GPIB Card
No the trouble Shooting wizard did not pick up any problems with the device.
Message 5 of 9
(5,008 Views)
I just want to make sure that you have an NI PCI-GPIB card, and not some other brand.
Message 6 of 9
(5,008 Views)
Yes, its a National Instruments PCI-GPIb card.
Message 7 of 9
(5,008 Views)
Are you logged in as a user with administrator priveleges? MAX may not be able to do some things if you are logged in as a regular user.
Message 8 of 9
(5,008 Views)
The control panel? It sounds like you have an old version of NI-488.2 installed. Try upgrading your driver.
- Uninstall the card from Device Manager
- Uninstall NI-488.2 from Add/Remove Programs
- if you have LabVIEW 6.0.2 or earlier and did not do a custom install w/o drivers I suggest you: uninstall, reboot, then reinstall LabVIEW. When you reinstall, do a custom install and click on Drivers folder and select "This feature will not be installed."
- Reboot and cancel out of the "Found New Hardware Popup"
- Install NI-488.2 ver 2.1
- Reboot
Message 9 of 9
(5,008 Views)
