GPIB control of HP 6034A power supply
I would like to find drivers for GPIB control of HP 6034A power supply (LabVIEW 6.1). There are drivers HP6xxxA for power supplies 6033A, 6035A, 6038A, ... Could anyone give me information how to modify these drivers for 6034A or any other directive. Jokut
(4,123 Views)
Have you tried using the 6034A with this driver. I would assume that Agilent uses the same command set for this family of instruments (they usually do).
The best way to find out is to get the programming manuals for these devices from Agilent's web site. With the manuals you can determine if there are any differences. In any case, the command set should be very similar. You could them make a copy of the Instrument driver VIs and replace the commands that are different for the new driver.
Hope this helps.
DiegoF
National Instruments.
(4,123 Views)
