GPIB how to avoid timeout , when reading emptry string
I am doing a gpib.read() . Sometimes when there is no data on the spectrum analyzer and I do a read() command I get a timeout. I know the reason why I get the time out b/c the pc is waiting for the data, but the data does not exist.
-How do I tell the system that there is no data coming do not timeout,but continue on with the code?
(3,293 Views)
The timeout that is returning is and error, and in order to continue on with the code you would just need to handle the error.  This is different for every language so I would suggest reading about how to handle error in the language you are programming.
Jensen
(3,280 Views)
