GPIB interface
Hi All,
I have a probelm communicating with two computers having GPIB interface in both the computers.
One computer (PC1) having the old GPIB card KPCI488, may be configured as controller.
and it is send the Low level commands through the GPIB interface.
The commands are like below.
UNT UNL MTA LISTEN 1 SEC DATA '0001' 13 10
in the above command I will recieve only 0001at the other computer side (PC2). Is it true, if i need to reading all the data at PC2, is there any thing I miss to configure the GPIB card at PC2 side?
UNL UTL TALK 1 SEC 5 MTA
what happens, if the above command send by PC1 and if it is reacieved at PC2?
The PC1 is very system having the Application software developed long back, which is not to be changed.
Muni
(3,534 Views)
Hello Munni,
It sounds like you are using Keithley PCI products.  Also the "commands" you are using are unfamiliar.  What in this setup is related to National Instruments?  How can we help?
Steven T.
(3,495 Views)
