GPIB is a Application "HOG".....
I would like to call out to my DMM through the GPIB WITHOUT my application freezing during the GPIB call !! Any suggestions would be great. 🙂 Thanks in advance.
(3,148 Views)
No one is going to be able to help much without you providing a lot more information. What language are you developing in? Are you using VISA or old GPIB calls? What is the DMM? Are you using a driver or something you wrote? Does your app stop during a read or during a write? How about attaching some example code that illustrates your problem? Any error messages or codes being generated? Does the command work in MAX?
(3,148 Views)
