GPIB not detecting when connected to internet
I have keysight power supply connected to PXI-8880 through GPIB, It is not detecting when connected to internet & Its detecting when its not connected. Can any body help me to resolve this issue.
(3,683 Views)
Accepted by topic author Samraj
This issue happens due to a conflict in the multiple network cards present in the system. It was a issue that used while detecting ethernet targets to system, which was resolved. But then this issue was also solved by doing the same. You can follow the link on how to change the order of network cards present in the system.
http://digital.ni.com/public.nsf/allkb/FD9E1AF5AB1343098625736F0076DE6B
You need to also make sure that IP Addresses of the network cards are different, otherwise conflict can occur there too.
Yaskadeva
India AE
National Instruments, India
There are only two ways to tell somebody thanks: Kudos and Marked Solutions 😛
(3,557 Views)
