GPIB string for Prologix USB-GPIB adapter
I have the misfortune to be working on a project with the wildly unpopular prologix USB-GPIB adapter.
I can communicate with an instrument through the prologix adapter by using the VISA string
ASRL4::INSTR
and then prefacing commands with ++addr{GPIB address}\r\n
e.g. ++addr\s1\r\n*IDN?\r\n
Is there a way I can directly address the GPIB device so I don't need to preface every command with ++addr\s1
Having consulted (http://zone.ni.com/reference/en-XX/help/370131S-01/ni-visa/visaresourcesyntaxandexamples/) I have tried a lot of combinations with no success.  Any help would be appreciated.
Rgds,
Seán
(4,897 Views)
use the NI version of this usb controller.
more expensive hardware less expensive software
greetings from the Netherlands
(4,853 Views)
I'm very disappointed to receive such a response.
I am contracting on a project and do no have the option of insisting they change their hardware.
I would appreciate a more helpful response.
Rgds,
Seán
(4,848 Views)
calculate how much they pay you and see what is helpful in such a case. Maybe buy the NI version yourself.
(4,843 Views)
If anyone can help, my question is what do I add to the sting below in order to address a GPIB device with address 1 using Nationa lInstruments VISA.
ASRL4::INSTR
Rgds,
Seán
(4,834 Views)
I created a vi that works seamlessly for most GPIB functions.
https://forums.ni.com/t5/Example-Program-Drafts/Prologix-GPIB-USB-Controller/ta-p/3539152
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,830 Views)
