GPIB using .NET
I have LabView but not Measurement Studio.  I would like to write .NET programs to access my GPIB instruments.  I have found some tips for that which led me to http://www.ni.com/download/ni-488.2-3.1.1/3786/en/ .  Here you can download the NI-488.2 3.1.1 drivers which are supposed to have Visual Studio hooks and help built in and work with .NET 4.5.
When I try to install the downloaded file ni4882_311.exe, I'm told that I need .NET v1.1 in order to run the installer.  What??  I need an ancient version of .NET in order to install NI drivers for the latest version?  .NET v1.1 does not install directly on Windows 7 so I found an elaborate procedure from Microsoft which supposedly would install it, but that fails telling me there are "compatibility issues".
So how do I install NI 3.1.1 GPIB drivers for use with .NET 4.5 on a Windows 7 machine?
(4,911 Views)
If you aren't going to use LabVIEW, why did you post here? Click on the Options link and request the moderator move your question to the instrument control board.
(4,900 Views)
Never mind -- I found version 3.1.2 and it installs fine.
(4,866 Views)
