GPIP-USB-HS dosen't work with a USB extension cable?
I have a new GPIB-USB-HS interface and it works fine when I connect it straight from my PC to an instrument. However, when I try to connect to a different instrument using a USB extension cable, MAX can't detect the instrument.
I want to use the extension cable because this instrument I need to communicate with is a power meter inside of a large power supply cabinet and the GPIB-USB-HS cable just isn't long enough.
I also tried connecting like this: PC > GPIB-USB-HS > GPIB cable > power meter. Same scenerio - Scan for instruments in MAX does not see the instrument.
Has anybody had any luck extending the cable length on a GPIB-USB?
Thanks - Paul
(4,934 Views)
Paul,
How long is the cable, or is it a "Fry's" USB extender? Another option might be to extend the GPIB side with a longer GPIB cable.
- Tim
Product Strategy
(4,920 Views)
Hi Paul,
In the second scenario, in which you use an extra GPIB cable to extend the reach of the GPIB-USB-HS, how long is the GPIB cable?  I use my GPIB-USB-HS in that manner all the time without problems.  Does this particular power meter work if you plug the GPIB-USB-HS directly into it?  From your original post it seemed like it may have been another instrument that you actually had working plugged in directly.
Jason S.
(4,894 Views)
It turns out I had the GPIB address set on the instrument wrong. (I was trying to write to device 1 and I had the device mistakenly setup as device 11.)
So now I can see the device (a yokogawa power meter) but I still can't write/read to it. I get an error from the instrument that I'm sending the wrong command. The odd thing is I'm sending the same commands that I was when using a NI PCI-GPIB card. I think there must be a different defalt setting in the NI 488 config. properties.
(4,887 Views)
Hi Paul,
I know this is an old thread, but did you ever figure this out? I'm having the same dilemma, so I'm unsure if I should extend the GPIB side or the USB side. Thanks.
(2,028 Views)
A USB extension cable should be fine, as long as it is a quality-made USB 2.0 cable which doesn't cause the overall cable length to exceed the 5m specified in the USB specification.
Low-cost or old cables might not work well at that maximum distance. Powered extenders are available, but my personal experience with these has been poor. The ones I have seen place the "powered unit" at one end of the cable, which still requires exceeding the standard in one direction. If you need to go beyond the allowable length I would recommend a powered USB hub, unless you have a powered extender you know to be reliable.
(2,010 Views)
