Gateway locks on install of PCI-GPIB
I am removing a PCI-GPIB card from a Dell 133Mhz where the card is recognized and installing in a Gateway GP7-800Mhz PIII. As soon as the card is installed the PC hangs on Boot after the the Hard Drive and CD is recognized. No error messages. I have tried in different slots expansion slots and still no go.
Message 1 of 10
(5,154 Views)
 You might want to install the NI-488 software first.
Message 2 of 10
(5,149 Views)
1. Can you confirm you have the latest BIOS from Gateway?
2. On the PCI-GPIB there should be a label that starts with either 183617 or 188513. Can you reply with the rest of what is printed on the label?
3. Can you try booting the system with no other PCI cards installed?
Message 3 of 10
(5,145 Views)
The newest version of the NI-488 software was installed first
Message 4 of 10
(5,132 Views)
1.  I do not have the latest version but when I download the updated BIOS and BOOT hte Diskette says it is not a Syten Disk
2.  Label is 183617G-01
3.  With no other PCI cards installs syetn boorts fine
Message 5 of 10
(5,130 Views)
     With
Message 6 of 10
(5,130 Views)
1.  I do not have the latest version but when I download the updated BIOS and BOOT hte Diskette says it is not a System Disk
3.  With no other PCI cards installs System boots fine
     With sound and NIC installed system boots fine
     When I install the GPIB either alone or with other cards system hangs
Message Edited by Uncle on 06-21-2006 07:42 AM
Message 7 of 10
(5,135 Views)
I can't guarantee it will solve your problem but I think you should first work on getting the BIOS upgraded. Are there any instructions from Gateway for upgrading the BIOS?
Message 8 of 10
(5,126 Views)
Are there instructions with the updated BIOS that tell you what to do with the BIOS file you updated?
But it does need to be a System Disk so that the PC can boot from it. With my Dell PC, the BIOS update came as an EXE file. When I ran the file, it took me step-by-step to create a bootable BIOS update disk.
Message 9 of 10
(5,120 Views)
Finally found an old Diskette that I used and BIOS is updated and GPIB card is recognized and system boots fine
Message 10 of 10
(5,116 Views)
