Get port binding info
Hi all.
Is there a reliable way to programmatically get know a com port to which a serial visa resource is bound? E.g. I can see in MAX that ASRL1 is bound to COM1 but how can I get this info in a VI at runtime (LV7 PDS, VISA 3.0)
Thanks in advance
(3,499 Views)
I think the best way for you to get that information would be to read and parse the visaconf.ini file. That file contains all alias information, and you could write a subroutine that parsed that file and filters out the information you are looking for. That particular file can be found on your computer in the following directory:
C:\VXIPNP\WinNT\NIvisa
Hope this helps!
Steven B.
Applications Engineering
(3,499 Views)
