Ghost GPIB instrument in NI-MAX
i'm really amazing that there is no solution from the creators of this software,, it is incredible ,, wonderful software and one bug cannot be solve ?  this is not new issue,, this problem existe from very long long versions before,,  and have not found  a solution GPIB Ghost
Is there no real support ,  NI corporation  seems to be having issues with their engineers ,   looks like not one technical support provide real answers ,, no one is paying attention  or there is no technical support knowledge available after COVID19
(971 Views)
Did this method work?
Santhosh
Soliton Technologies
(947 Views)
If you read my explanation under the GPIB Ghost topic, you should have understood that it is not a bug.  There is actually a benefit to NOT having it automatically re-read for instruments.
Instruments that may be detached, can be simulated using the current configuration rather than creating a hardware error when hardware is not physically present.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(905 Views)
