Gpib and Windows XpMode
Hi
we got an Gpib-usb-hs, SN HA6934396 , and i want to install it in a Virtual Machine with XpMode .
I downloaded the last software version and driver from NI site NI-488.2 2.7.3 and installed this in the virtual machine but when connect the usb Gpib don't install correctly the drivers and don't work ...
Is there a solution for this issue ?
thanks for the support
Moreno
(3,536 Views)
Which Virtual Machine are you using for Windows XP virtualization?
If you're using Windows 7's XP Mode, look at this post:
http://social.answers.microsoft.com/Forums/en/vistagaming/thread/d1cac62c-d2d7-4fa0-8738-92bc2585dea...
it seems that in order for you to use a USB device in virtual Windows XP, you also have to install the Windows 7 drivers of your device and install it into the virtual machine.
Hope it helps
Luca Gallo
Sales Engineer
(3,510 Views)
