Gpib enet configuration problem
I have the following problem:
ever since I reloaded a ghost image on the computer (cause of some vi's didn't work anymore after I updated VISA) I cannot configure the GPIB - ENET /100 correctly.
It seems that every time I restart the computer I have to reconfigure the ENET100??
The configuration itself is straight forward and if I finish I get no error message or whatsoever.
And all seems to work fine...
After the restart the Interface is present in the interface list in Max, but when I try to search for instruments an error windows pops up with the message that the interface is not correctly configured.
So each time I restart I have to go to the whole installation process...leaving the computer on all the time is no option.
Any idea what the problem might be??
Thanks alot.
Bye for now
(3,282 Views)
I believe you're talking about the error that says something like "The GPIB0 ( ) interface has been incorrectly configured, Run Troubleshooting Wizard..."
This error usually indicates that there is an IP connectivity problem between the devices. Here is a KnowledgeBase article on the issue that may be of some assistance.
Can you ping the ENET/100 as soon as you boot? If not, that's probably why you're getting this message. When you go through the whole installation process, do you actually re-assign the IP address, or just delete and re-add the GPIB device in MAX? Can you see the device when you search for it?
Hope this helps, or at least we can clarify the problem more.
Scott
(3,282 Views)
