HART driver for Brooks MFC
I am afraid I cannot help. I do not have access any longer to one of these brooks mass flow controllers.
The only thing I can suggest is to check if all paramters to constructor.vi are coupled and to make sure that your cable to the instrument works fine, meaning that you have included the terminating 120ohm resistor for IEEE485 connection and wired all cables correctly to your COM port!
MAYBE SOMEONE CAN POST A WORKING EXAMPLE?
Pieter
Message 21 of 34
(5,769 Views)
Hello Pieter
Thanks for your answer , maybe you have some instructions to test my Mass Flow communication by Mesurement & AUtomation, I will can be sure of my linking
I'm not sure that Mass Flow answer
DO you have informations ?
Thank you
Message 22 of 34
(5,746 Views)
Hello!
I am also trying to get 4 Mass Flow Controllers 5850S vom Brooks connected to LabView.
They are wired via RS485 and I am trying to use the vi`s I found in this forum.
Does anybody know what values i have to enter in "device id" and baud rate etc?
Thank You!
Message 23 of 34
(5,482 Views)
As far as I remember,
Device ID is the number written on the Mass Flow Controller MINUS a zero somewhere in the number, check the LabVIEW code provided to know which zero to delete (this was added as comment in the relevant VI)
Baud Rate: Check manual or phone Brooks
Message 24 of 34
(5,476 Views)
Is there anyone who have these software and uploading for me :
Brooks Smart control.
brooks Smart DDE.
I already perform some test drivers, but with some of 5850S there is some bugs.
I would like to fix/test with these software --> not supported / provided anymore by Brooks (without emerson now).
Thanks a lot for uploading me this (on http://dl.free.fr/)
I will give you my test software/drivers after debugging (it works correctly with 0154 gateway), if you're interrested.
[URL=http://img130.imageshack.us/i/testbrooks.png/][IMG]http://img130.imageshack.us/img130/930/testbrooks.png[/IMG][/URL]
Message 25 of 34
(4,894 Views)
up
thanks
Message 26 of 34
(4,853 Views)
hello
is anyone have working driver for books mass-flow ?
i tryed with the dll and all the VI i founded but i can't make anyone work.
Message 27 of 34
(4,412 Views)
I keep randomly getting "error 5001" when I read the MFC with the Brooks vis posted here. The error stops my program and then the program continues when I push the continue button. If the error occurs again it will stop the program again. I tired the clear the error before it stops the program, but this didn't seem to help. Any suggestion would be helpful.
One screen shot of the whole vi is attached.
20555iA5D4323162A289AA
Five screen shots of the error are attached.
20557iDA1F4AE34111F9C3
20559i6D7935BCD5FF99D4
20561iDD5A3D6E24881DD3
20563i1F33C63591334185
20565iEC7E5BF4CD34159D
Message 28 of 34
(4,284 Views)
Message 29 of 34
(4,283 Views)
I would invetigate why you get a checksum error.
greetings from the Netherlands
Message 30 of 34
(4,270 Views)
