HM8118 Hameg usb connection issue
Greeting all
                I’m sorry to bother you but I was wondering if you could help me with a software Issue. I’ve the HM8118 LCR Bridge/Meter (Rohde&Schwarz), and I used it regularly for logging data with the LabVIEW interface. Recently I haven’t been able to save the data in the computer I use because it seems there is some trouble with the labview interface, at first I thought it was the driver, but my computer does recognize the HM8118 well but the labview project doesn’t. I have tried reinstalling the driver and even changed the labview version (2013, 2014 and 2015), but still I haven’t been able to log data or to even recognize the device with the sw.
I hope you can understand and give me some piece of advice, thanks in advance for your attention and best regards.
(4,263 Views)
Hi Mikhapiensa,
can you provide the IO Trace Log from one run on your code? From your description it's not very clear whether the VISA connection fails or reading of the data fails. The IO Trace log will show that...
Milo
(4,201 Views)
Hey Mikhapiensa!
Can you send a screenshot of NI MAX showing up the devices connected in your computer?
Even a MAX tech report could be good.
You do have VISA installed?
(4,186 Views)
Hello. I've the same problem.
How did you solved it?
(3,573 Views)
