HOW TO INCREASE OR DECREASE TIME DELAY TO SAVE DATA FROM OSCILLOSCOPE
Hi there, i am using RIGOL 1052E oscilloscope to save data in my laptop using USB interface with Lab View. I am using RIGOL DS1000 series delay VI found from instrument drivers. Default time delay is 2000 ms but when i increase or decrease time delay and as soon as i run VI, it goes to 2000 ms automatically.
You can see attached VI, i am new to Lab View, will be happy to see the response.
Many thanks
(2,960 Views)
No need to shout!  unless your keyboard has a broken caps lock key  (If so, kindly ask us to ignore the all caps OK?)
Without the "xxx...Delay.vi" I really can't help you determine if you are using it improperly or if there is a bug.  No workaround can be found.
(2,944 Views)
