HOW TO PERFORM CURRENT MEASUREMENT USING KEITHLEY 2700 IN LABVIEW
Settings conflict errors usually mean your card doesn't support that type of measurement.  In the picture you have 2 DC voltage measurements but in the the code you have a DC Voltage and then a Resistance measurement.
What card are you using?
Craig
Message 11 of 14
(1,676 Views)
We are using the 7700 20 Channel Multiplec Card
Message 12 of 14
(1,651 Views)
We have the same card 7700 20 Channel Multiplec Card.
I try to read the following channels:
113 - VDC
112 - Temperature
When I run vi named as 'k2700_read_DCV_then_temp.vi' i get the following error during second measurement:
-1074000000
<ERR> ke27xx Error Query;
instrument reports:
-221,"Settings conflict"
What works for me is 'Open communication -> Read Temperature -> close' then 'Open communication -> Read VDC-> close' ...
Questions:
1) Is this the only way i can read multiple channels?
2) Is it recomended so that channels be one after the other? ( E.g. channels 112,113,114,115...) Units: Voltage, Voltage, Temp, Temp..
Message 13 of 14
(1,178 Views)
Hi
You don't need to close the communication between commands but you probably have a conflict in the order you set the ranges. Some combinations of ranges are generating conflicts.
Ihad problems with Amp ranging and Volt ranging until i found out that a high voltage range does not fit with a high current range. So the order in which you change the ranges is important.
The reason it probably works when closing the communication is the reset to a default state when opening the communication, but this is a very slow process.
good luck.
greetings from the Netherlands
Message 14 of 14
(1,166 Views)
