HP 3652A interface with MATLAB
I am trying to connect to an HP 3562A Dynamic Signal Analyzer (DSA) using MATLAB, with an NI GPIB-USB-HS cable. I have a VISA connection established with the DSA and am trying to send it simple commands such as "FRS?", but any command I send to it (no matter the complexity), I get a timeout. This is a pretty old DSA and the programming manual is written in BASIC. I would be grateful if anyone could guide me on what I could potentially do. Is there a compatible syntax or a work around, if any exist?
Thanks a million.
(5,464 Views)
If the only NI part is a cable, you should probably ask elsewhere (MATLAB forum, for example). 😄
(5,455 Views)
Hello Bhafshar,
Do you have the proper drivers installed for the HP 3562A? I found the following link that should work with your device:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=145
If you do have the drivers installed, make sure that you do not have a firewall that prevents you from using the device or a lack of administrative privileges.
Since the only NI component is the cable, I would recommend reaching out to the other companies involved with your system.
(5,430 Views)
I don't know if this will help. I wrote some code for an old HP 3561A DSA that dates from 1986.
I had to add a semi-colon to the end of each command.
Curt
m_device.Write("MKPK;\n");
m_device.Write("RDMK;\n");
reading = m_device.ReadString();
(5,369 Views)
