HP 5890 printing graphs
Logical,
Could you tell us which OS that HP computer is running. Also, some more information as to what type of devices you would need to take measurements from would be helpful. Our software is designed to run on a pre-existing OS and then acquire data / provide control of certain instruments. I am guessing it would be possible to use LabVIEW to control some of the instruments on this machine, but depending on what instruments those are we may or may not have pre-built drivers for those devices. If we do not have anything pre-built it would require you to do a lot of programming to get these devices working properly. Even if we do have some pre-built drivers made you would then need to write a software program that would do the acquisition of your data and then plot it and print out the graph.
If you could give me some more details on the OS the machine is running and instruments that are being used I could give you some more information. Thanks!
Aaron W.
CLA, CTA and CPI
Message 11 of 11
(910 Views)
