11-20-2009 07:20 AM
11-23-2009 11:32 AM
ahamel,
Be sure you have the latest version of NI-VISA installed. Also, do you see your GPIB device in MAX? If not, you should follow these steps.
You can confrim which version is installed under the Software section in MAX. If you are still having trouble after installing the file from the link above, then take a screenshot of your MAX window with all the items in the left window expanded. This will help illustrate what you have going on in your system.
11-23-2009 02:15 PM
11-24-2009 09:33 AM
