HP/Aligent 33120a single burst of a sine with modulated amplitude
Hello everybody,
I´ve been trying to generate a single burst signal consisting of a sine with modulated amplitude. I can generate either the burst signal or the sine with the modulated amplitude, but separately. My gold is to merge the two steps to produce the kind of signal that I want. It should look like the attached figure. My question would be if that is even possible to make with the Aligent 33120a, and most importantly, how.
I´ve been trying to make a VI in Labview to produce this signal, but it doesn´t work. But i guess that is a question for later.
Thank you for your answers
(4,020 Views)
@racso100 wrote:
Hello everybody,
Have you verified that you generate the signal you want by simply using the buttons on the instrument?
If not, hadn't you do that first?
Once you are able to do so, you should then read the programmer's manual to see how to do it remotely.
(4,010 Views)
