HP3585A
I am plotting HP 3585A display using the ibrdf command, then using an excel
macro to plot the data. It works, but the ibrdf command takes around one
minute to time out. Is there any way to speed up this operation? I am using
a NI PCII card on a Pentium with Windows 3.11.
Also I have used the ibrd command but the variable seems to "choke" after
300 points.
Any suggestions?
Thank you,
David Gelfand,
Regulatory Approvals Group Leader
Memotec Communications Inc.
Montreal Canada
Message 1 of 1
(4,598 Views)
