HP5350B not responding to GPIB commands
I have been using the HP5350B, an old HP frequency counter for a remote control application. I am using the GPIB commands to send and receive messages from the instrument. I have attached the screen shot of the code which uses a GPIB read block to read the value from the instrument. Earlier when I used a GPIB-USB-HS connector I was able to get the desired values using this code. Recently I got a PCI-GPIB card which I installed in my computer and ever since have been trying to read measages from the instrument with this card in the computer, but I have not had success at reading the value from the instrument using the same code. I have been getting the error shown in the attachement. The only difference I found between using the GPIB-USB-HS and PCI-GPIB card is the change in the address of the instrument from GPIB1::7::INSTR(for PCI-GPIB card) to GPIB0::7::INSTR (GPIB-USB-HS) which showed up in NI MAX.
Now when I connect the GPIB-USB-HS back to the computer and try communicating with the device with the same code I am unable to reproduce the results I was getting earlier. I would really appreciate any comments in helping me resolve this issue.
Thank You,
Vivek
(4,555 Views)
Accepted by topic author vivek.madhavan.13
Straight from the LabVIEW Help file
When there are multiple GPIB controllers that LabVIEW can use, a prefix to address string in the form ID:address (or ID: if no address is necessary) determines the controller that a specific function uses. For example, to set GPIB controller 2 to talk to a device on address 3, use the prefix 2:3. If a controller ID is not present, the function defaults to controller (or bus) number 0.
You have changed your hardware configuration such that "7" is no longer unambigeous.  use "0:7" or "1:7"
(4,545 Views)
Thank you Jeff for your support. It was very helpful.
Thanks again,
Vivek
(4,520 Views)
