i am using an event delay type trigger on a HP54845A scope to aquire data on channel 1. The triggering is in the following order.
The event source is channel4, the arm source is channel 2 and my target data in on channel 1.
I have the setup loaded on the scope and when i use a labview program (6.1) to simply set the triggering (HP548xx configure trigger.vi followed by
HP548xx config event delay trig source.vi) and acquire the data off channel 1 it works fine.
However when i try to program the entire operation including enabling channels 2 and 4 and setting their characteristics
before my trigger subsystem i start getting a read timeout from my read operation. i have entered in the exact values for my vertical offset etc.
for the channels that i have on my scope setup. Additionally, i have a case structure to abort acquisition and reset scope to default
if the same error code is encountered. although i can see the boolean for this to come out 'true' the end result is that my scope hangs and
i have to power off and on to get it started again. I am using the HP54845A drivers and GPIB. Any help in this regard is most appreciated
and will earn you a beer.
Best Regards
Sam
