HP75000 support
I have an HP75000 scanning DVM (w/ E1411B voltmeter)
that works with NI Measure. I don't have a LV driver
for it. MAX sees the instrument and correctly identifies it, but I haven't been able to get it to
respond to commands using the GPIB Write.vi and
GPIB Read.vi. I'm looking for any helpful hints, or
if anyone knows of a driver for this instrument.
(3,811 Views)
Go to Help»Examples»I/O Interfaces»GPIB»LabVIEW<->GPIB. Enter the primary address of the instrument, set both dip switches in the up position, and try sending a simple query to the instrument. If MAX correctly identifies your instrument with a scan for instruments, then your instrument will respond to a *IDN? query.
(3,811 Views)
