HP8753ES save/recall state
I am trying to recall state information to the HP8753ES by using LabVIEW. I have problems when I use HP8753 Save/Racall State.vi with the HP8753ES network analzer. The error comes when the vi sends the command INPULEAS (input learn string)to the analyzer following with the learn string that I saved. At the analyzer's display, it read "block input error". But I got no error when I save state information using that VI. Is there a way recall state properly?
(4,030 Views)
I was unable to find the a driver for the HP8753ES at http://zone.ni.com/idnet97.nsf/browse/
Where did you obtain this driver?
I would check the instrument's user manual to see what command is required to recall state information and run NI-SPY to see if that command is being sent properly.
(4,029 Views)
I use HP 8753x driver. I tried the command from the manual, but it didn't work.
(4,029 Views)
has anyone figured out a solution to this problem. I am currently getting the same error (caution: block input control) every time I send a learn string back to my analyzer. is there an solution to this?
(3,809 Views)
Drivers for 8753ES
Have a great weekend,
NathanT
(3,801 Views)
