Having problems transferring WT500 measurement data from gpib/usb to csv file.
Gentlemen,
I have been trying to integrate the WT500 via gpib; taking instrument data and saving that to a spreadsheet file with headers. Because I have a different DUT each time I test I elected to be able to read the bar code into the vi (beginning of each row) below the main header.  I can't make that happen.  The scanned text comes in via usb fine, but it won't behave after that.  It appears it needs to be a string, otherwise it filters out all the alphabet characters and leaves numbers only.  That's a problem where I need both because I don't know how to combine those two in a array to be saved as shown as attached..  Further when I close this vi it won't save the headers assignments.  I have to retype them all over again.
Any suggestions would be appreciated.
Eric
(2,621 Views)
Attaching a lvproj file is not useful, because it does not contain any code.
(2,608 Views)
