Help with RS232 to USB
First-time poster here - hello!
I  am using LabView 7.0 Express to read data from two intruments - an Ohaus balance (with an NI driver) and a Thermo pH/Conductivity meter (no driver).  Both have serial RS232 outputs, and I have no trouble communicating with the balance.  Since there is no driver that I know of yet written for the Thermo meter, I think I should use the Driver Wizard that is part of VISA.  However, one of the first options is whether the device is PCI or USB.  That makes me think that I need a RS232 to USB converter to even develop a driver with the wizard (I have little programming knowledge).   Is there an easier way to control the serial device perhaps without a driver?
Thanks - I look forward to contributing what I can to the NI community.
Ingram
(3,178 Views)
You do not use the VISA driver wizard at all. The type of driver that creates is not at all applicable. With that, you can do low level read/writes to pci or usb devices. You are not trying to communicate to either. You are trying to communicate to a serial instrument. You just have to use the VISA Read and Write functions or the Instrument I/O Assistant. There are shipping examples for serial communication.
(3,176 Views)
