Help with USB Instrument Control Tutorial
I don't get an error or something, the wizzard finishes as it should be and i can choose the created inf file. I can execute exactly the same steps as it is mentioned in the tutorial. The only problem I have, I can't see the device in the measurement & automation tool, so I assumed I am not able to use in in LV.
I have found today a LV libaray from the supplier, so I am able to run it (Sorry, I should had post it), but i thought I have to see the device in the M&A tool to run corect.
Message Edited by Lord Chaos on 02-13-2008 10:27 AM
Message 11 of 11
(1,118 Views)
