Help with initiating an TGA1242 in labview via GPIB
Hi
I have a problem that is really annoying. When I try to initiate TGA 1242 (Arbitary waveform generator) it just stops in a menu on the instrument. Labview thinks that the initiation worked perfectly but later on when I try to control it, Labview tells that the instrument is not initiated.
I have tried NI Spy and when the initiating starts there is a communication stream in the GPIB interface but it stops when "ibwrt(UD0, "BEEPMODE ERROR.",15 (0xF)) is sent. The display on the instrument then shows the error menu with warnbeep OFF.
I have also tried Measurement & Automation EXplorer. "Communicate with instrument" works as expected.
Is there anyone out ther who can help me out?
(3,297 Views)
Hello David!
Are you using a LabView driver for your instrument?
BR
Ashwani S.
National Instruments Sweden
(3,276 Views)
The problem is solved.
It is totally normal that the Waveform generator ends up in the error menu after initiation
Thank you anyway!
(3,272 Views)
