Help with rs485 from a Newport iserver.
Hi
Im "green" with rs485. I have 5 process meters that will be connected to a Newport iServer to convert it to a webpage. The question I have is how do I make a vi to display all the meters on a single page? And do I need any special drivers to pull the data from the iServer?
Thanks alot
(3,226 Views)
I'm assuming you are using the Newport iServer to connect your rs485 meters to your tcp/ip network.  Is this correct?  If so, you should be able to configure Measurement & Automation Explorer to communicate with the meters so you can use them in LabVIEW.  See the following link for directions on how to do this: How Do I Configure an Instrument to Communicate via TCP/IP in MAX?
Robert Mortensen
Software Engineer
(3,209 Views)
