Hex 0xBFFF000E
i am using visa library and i have error
VISA:  (Hex 0xBFFF000E) The given session or object reference is invalid.
in visa write and read....look at attachment
(5,033 Views)
The picture does not help at all. You need to provide the VISA Resource Name that you are using. You would use the pull-down of the control to select the resources that are available on your pc.
(5,029 Views)
vresource name is com2
(5,013 Views)
And did you do what I said and select out from the pull down or did you do something silly like type it in?
(5,006 Views)
