Hexadecimal to float-point?
Hi, i'm working with modbus and i get a hexadecimal value but i need the value in float-point format, can help me??
(3,636 Views)
Hi Arsintek,
What programming language are you using to read in the data and do the conversion?  In LabVIEW, there is a hexidecimal string to decimal number VI in the string palette that may do exactly what you are looking for.  The method to convert the datatype will be different for different programming languages.
john m
(3,618 Views)
Is your problem just a matter of display, or are you receiving a floatting point number under machine format (ie 4 bytes for a single precision float) ?
In the latter case, use the type cast function as in the attached vi. Depending on the connected instrument, you may need to revert the byte order in your hex number to read something understandable.
Chilly Charly    (aka CC)
(3,613 Views)
